Discuss Earthing selv lights in the UK Electrical Forum area at ElectriciansForums.net
If you Earth something then it sure as hell isn't SELV. (The whole point of SELV is that it is separated from Earth.)
Correct. With an integrated power supply, the primary side may be Class I and the secondary may be SELV. But that would make the whole housing Class I and needing earthing.
BUT BUT, the whole may have been constructed as a double insulated assembly.
Isf this is the case, there should be a double insulated logo on the thing.
@Anders does it have this symbol on it?
Please provide a photo of teh light's label, or maybe tell us what the installation instructions say......;)
I did ask that earlier and I think he said it was indeed double insulated.
Reply to Earthing selv lights in the UK Electrical Forum area at ElectriciansForums.net
Hi all Suggestions please. I’m working on a 3 phase shop install with a bunch of typical circuits. As each cct is energised the earth leakage...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
