Discuss Eicr,oh the joys of sparkies... in the UK Electrical Forum area at ElectriciansForums.net
so it's bordering between a C! and a C2, i
Sounds like a TT system with a dodgy earthing terminal.
There are other likely culprits along the way. Earth loop testing through a RCBO?
I would first check the earthing system.
Earthing from a fortuitous routing or some pretty lousy conections or there really is no earth in the socket circuit or all of them.
I'd have to agree with Ian on this. The circuit does not meet ADS due to very high impedance, however it would require a fault to present an immediate danger. C2 for me.
Reply to Eicr,oh the joys of sparkies... in the UK Electrical Forum area at ElectriciansForums.net
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Just wanted to get some thoughts from other electricians who regularly do EICRS, does anyone else code a fan isolater with no 3A fuse protection?
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Hello there. I've been looking around here and found some conflicting information. I have a question if I may ask. I had an electrician come over...
4K
