I
ianphilip007
hi guys
after some advice have run a 4mm t+e cable, along the gable end wall in the loft 300mm above current level of insulation. it is a bungalowe where it reaches the sofit in the eaves there is very limited space for me to get in and clip as usual. the cable is secured firmly just not as neatly as i would like. do you think the assessor will actually enter the loft at all or should i try and squeeze my self in to do a neater job.many thanks
