Discuss Electronic ballast testing in the UK Electrical Forum area at ElectriciansForums.net
Can anyone help with me with regards to testing this electronic ballast, there’s 240v at terminals but I’m not sure how to see if the ballast is faulty.
Yes I know, I want to understand why and how to test is output DC or AC want to know for when I have a problem again
You'd probably have to have a better understanding of electronics than is necessary for the average electrician and the correct test equipment which again, the average electrician wont have so Andy5678's solution is probably the most cost effective.
Because of the complexity of electronic ballasts, the number of possible failure modes and their interaction with the lamp, in the absence of any other instructions from the manufacturer the only effective test is to put them under operating conditions with a known good lamp. Otherwise, it's like 'testing' a car engine without starting it.
The output is usually high-frequency AC with approximately constant-current regulation when running, but the currents and voltages vary according to whether it is pre-heating, starting, running or locked out. Modern microcontroller-based ballasts continuously analyse the lamp behaviour and react accordingly. They will sit there waiting until they detect that a potentially operational lamp is connected. They will then attempt to start it, check its performance, and shut down if it is out of spec to prevent energy wastage and annoying flickering. Some will then remain permanently on standby, monitoring whether the lamp has been changed, and start again from the beginning when happens.
Like the mice in the Hitch-Hiker's Guide to the Galaxy, when you think you're testing the ballast, it's actually testing you.
As Lucien mentions , you need a good lamp .
If it's one ot those D shape things ,
need to test the heaters with an Ohm meter !
(nothing connected and OFF)
( a wattmeter on the mains -with ballast hooked up !)
Micro-controlled ... Are we in ON-OFF-ON territory ?
Reply to Electronic ballast testing in the UK Electrical Forum area at ElectriciansForums.net
Evening. Got my hands on a pair of choke ballasts to run fluorescent tubes a few days ago and I want to see if they're in good condition. If...
Hi: I am the custodian at Peru Public Library, Peru IL. About 20 years ago, I installed about 150 new General Electric brand electronic ballasts...
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
Hello! Hope you’re all keeping well! I’m replacing a fluorescent tube light which had an electronic ballast fitting - I’ve ripped this out and...
I have narrowed the fault down to the ballast in this fitting. See picture. I cannot find an identical ballast. Blimey, there must be hundreds...
