Discuss electronic transformers in the Canada area at ElectriciansForums.net
They're switching converters. The AC input is rectified and smoothed, a PWM pulse train is then driven through a small flyback transformer. A feedback winding is then used to estimate the voltage on the low voltage side of the transformer. More expensive converters will use an opto-isolator to determine the voltage on the low voltage side of the transformer.
They're sensitive to high voltages, so don't do flash tests on them.
SteveyG thanks for the info , i did flash test them and they failed so i guess 1500 vac at 5 ma did these no good at all.
Reply to electronic transformers in the Canada area at ElectriciansForums.net
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Welcome to Accelleo! We are excited to present an excellent opportunity for Electronic Engineers to work within the Security and Defence space...
I’m just finishing my L2 2365 at college in the evenings and plan to do the L3 2365 with the same college as an evening course. However I would...
We are a UK registered Electrical company with a large contract based in and around Toronto, Canada. Are you looking for work? We have a...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
