Discuss extending cat 6 in the Computer and Networking Forum area at ElectriciansForums.net
I have to extend 6 CAT6. Cables that are being moved to a new cabnet, what is the best way of doing this? Are there junction box types for cat6? The neater the better but it will be above a false ceiling, I can't think of what to use never had to extend it before.
I think as a general rule it shouldn't be joined.
But I've never yet had a joint fail when I've soldered and heatshrinked them. The important thing is to maintain the twists of the pairs and the separating divider through the joint
How many cables have you, you can get junction boxes although i've never had the luxury of using them, i have seen myself using a rj45 module and piggy backing both cables into one module it's not great but it works, i've also seen myself using strip connectors, i would not advise this i was sent to do it as a 2nd year apprentice by my boss who was too lazy to get proper junction box (i still regard this as the biggest botch job of my life)
Plugs / Boots and Connectors : Cat6 Cable Connection Box - Black
I used v similar from rs components to extend some cat 5e to a new position loads of times
these will do the trick.
Get yourself a Krone backmount or profile frame and use 3 krone cat 6 highband modules , each module takes 2 cables and will maintain the cable performance. Doing it this way is classed as a consolidation point and perfectly acceptable.
A lot of large office fit outs use CP's dotted around with a patch panels worth of cables (24) terminated in them so that future additional points are easily added and you dont have to go all the way back to a busy comms room.
Hope this helps you out.
Reply to extending cat 6 in the Computer and Networking Forum area at ElectriciansForums.net
Hey everyone, working on a new build house and outside garage is wired up like this, however customer wants a Garage Consumer Unit instead of the...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
I hope this is the right place for this. I have one phone line in my house and its a cat 6. I'm planning on adding a line in our kitchen, so my...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
