Discuss Extending ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Morning all, i plan on extending ring circuit, installing additional 13A socket in the room.
Plan of action was to install black 30A junction box under floorboard to one of the legs. However after some research on this forum, junction box must be easily accessible and not suitable for the job. I'm not too sure if i will either go with carpet or permanent laminate flooring.
What would you guys suggest, 3 wagos inside existing backbox and extending from that
Or
Wago box under floorboard
Or blue crimps again inside the boxbox.
Thank you in advance.
wagos in existing socket box for me. if only 1 socket added, no need for FCU. unless you don't want to chase decor. in that case a MF box under floor.
Or
Why not extend the circuit from the sockets themselves? Removing the need for any junction boxes.
Screwfix have gaping holes in their catalogue .........
Must have been a glitch somewhere then Mate, when I worked for them the stock control was very good.
The OP intends extending the ring, not spuring off from the ring.
I would use crimps in the back box.
If the OP spurred from the nearest socket outlet, then he wouldn't need to crimp anything!
Reply to Extending ring circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have come to extend a ring main on the old wiring (red and black) and have used the wago 222 connectors to extend each leg and extended each leg...
4K
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
Evening all, Been to a job on Fri where the customer had a condition report completed. Two of the remedial identified was that there were too...
Hi I am seeking help and best practices to achieve below tasks. I am not across regulations hence will appreciate best approach to achieve below...
