Discuss Extract hood. in the DIY Electrical Advice area at ElectriciansForums.net
I have a Neff cooker hood which obviously needs wiring in. The cable is fitted with a 3 pin plug. The cable exits the top of the hood very close to where the ductwork also exits the top. When I fit the ducting covers the cable will be inside this. so either I drill the ducting cover, which I am not keen on or the cable and plug at some point enter the ceiling void. I did think about putting a socket on the upstairs floorboards, but knowing my luck the plug would fall out. Cannot recall my last hood but is it normal for them to have a plug or do most people just cut it off and wire by some other method than into a socket?
If there is a vertical chimney above the hood, then often a power outlet will be provided in this chimney, maybe a little off-centre to avoid being directly behind ducting. With either a single socket, or switched FCU depending on preference (some manufacturers like to scare their customers that they will void any guarantee if they cut the plug off).
I think you are spot on there. Looking at the drawings of how to install the thing I could not understand the circle I have arrowed. Obvious now after your comments that it is meant to be a socket. Pity they make no mention of it in the instructions. Many thanks.
Reply to Extract hood. in the DIY Electrical Advice area at ElectriciansForums.net
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi I am looking for some help. My Rangemaster cooker hood stopped working sometime ago, I’ve stripped the hood down and degreased the hood. Ive...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
