Discuss Extractor cooker hood efficiency in the Electrical Tools and Products area at ElectriciansForums.net
W
Will2
I am about to fit a cooker hood with extractor. The vent is some 12 feet from the hood; one bend only. Can someone tell me what capacity (cubic metres per hour) of fan would be required to "blow" that distance?
Thanks in anticipation
Will2
The last cooker hood i fitted, the pipe had not to run further than 3 meters. does it not mention in the instructions.
Usually you would work this out the other way around. You calculate the volume of air you need to extract either by referring to council regswhich will give you min requirements in room changes/hour or you look at the face area of the hood and the velocity required and get you volume from there.
Once you have your required volume you need to work out your system static pressure at that volume and specify a fan that is on-curve for those figures. The other considerations that might affect your choice of fan are the noise figures, the physical size, the energy consumption, whether it's speed controllable, does it need 'ex' rating or special high ambient temperature requirements etc.
If you're unsure about specifying fans then approach a respectable wholesaler with the specs of your system and they'll be happy to offer you some options.
Reply to Extractor cooker hood efficiency in the Electrical Tools and Products area at ElectriciansForums.net
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi I am looking for some help. My Rangemaster cooker hood stopped working sometime ago, I’ve stripped the hood down and degreased the hood. Ive...
Hi I can’t get hold of my electrician so was hoping for some help, a cooker hood is going on the wall but there is only a back box with wiring for...
