R
rjm84
Hi , just a question regarding wiring for extractor, I've had house rewired but extractor was not connected and spark doesn't seem to be coming back, the extractor wiring seems to be in place , there is white 3 core flex running from extractor in bathroom to 3pole fan extractor isolator on landing , and from extractor isolator switch to loft with about 1m excess just left not wired
the nearest junction box has 4 cables in it so is already full, can I cut a junction box into the live feeding that junction box, and put another junction box before it and wire the extractor into it?
the other thing is , the lighting cable is 1.5mm twin and earth but the flex is 1mm, would the downsize of cable matter ? Or would I need to put a junction box into the live with 1.5 mm coming off it into a un switched fused unit and then wire the extractor into that, also the fused unit will come as 13a, would I need to change the fuse to 5a or 3a or leave as 13 a ?
Many swift replies would be greatly appreciated as I need to board the loft asap but need to finalise this connection so any help would be greatly appreciated
