Discuss Extraneous bonds values in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This should generate some interesting replies! Good question.
off the top of my head it's mentioned in GN3. I think. Will go and have a look am a bit rusty
Lucky Nigel didn't ask you that one then Spartykus! :wink:
There is no reg that I know of.
It is mentioned in GN3 in the description of continuity testing. I would suggest that GN8 would have more in depth info regarding bonding though.
and what if the bonding conductors are each 10m of 6mm?
I had a reading that was 0.5 ohms, and consultant was saying oh that's too high. I was like WTF, are you seriously suggesting that that is not a short circuit? In fact the reading can go much higher and still be a good connection. It's just pure bull.
As nobody can pull any regulation out, just guidance notes, gives me a good argument.
From where to where?
It has nothing to do with short circuit.
How do you work that out?
It's not a regulation but -
See if you can connect a piece of cable to a pipe and get a reading of more than half an ohm.
Mostly I was getting 0.05 ohms, but in this particular area it was 0.5
Consultant said to run a bond from board to pedal stool. I said I would once all the flooring had been completed. Reply was because the floor was incomplete it can become live. Utter bull****.
The reading was taken from a wall socket earth to the access floor tile.
I don't really understand that but -
I think everyone assumed, I did, that you were referring to Main Bonding for which the figure of 0.05 ohms is usually quoted.
Again, I don't understand.
Is the floor metal?
You are probably right.
Bonding is not applied in case the floor (or anything else) becomes live.
If it is a metal floor and you bond it then the reading will be a lot less than 0.5 ohm.
In that case, if you are getting 0.5 ohms between socket CPC and floor then it must be bonded somewhere already.
Is he on about supplementary bonding between socket CPC and floor?
Running a main bond from stool to board would be strange.
its ridiculous, i have come across these floors before.
metal pedestals bolted to floor with metal covered wooden tiles ontop, usually covered with carpet tiles
Sorry I was nor clear, we was just taking measurements, no bonds were actually in place. The floor will get an earth via floor boxes.
However we was measuring continuity between wall socket cpc, and tile.
All extraneous earth's were measured.
From uni strut to tray work to trunking to ceiling grid to steelwork etc etc etc.
I was just trying to clarify if there was actually an regulation that stated these measurements should be below 0.05 ohms
it would be a lot lower from unistrut etc to it.
it will probably only have 2.5/4mm cpc at most.
there was so many glanded swa and steel in last plantroom the cpc reading was a lot lower than L-N because of parralel paths etc
Reply to Extraneous bonds values in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If extraneous structural steel is not exposed does it still require bonding Thanks
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi , Could someone answer the following for me? i don't have reg book handy and when i google i'm getting mixed answers. 1. maximum...
OLDBOY
O
I am a lecturer teaching electrical installations and in reading through the on-site guide to prepare a lesson I have come across a section I have...
Hi All, Can anyone help with calculating a Zs value for the fuse described in the title. The fuse sizes in Fig 3A3(c) of the 18th edition wiring...
