Discuss Feed to switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all
I work in modular buildings and we always wire our lights (In flat T&E) with the feed going to the switch. However at college they are quite adament that this is not a good way to do things, Is there anywere in the regs that says this? Or is there any reason why we shouldn't wire our lights this way?
Thanks again
Jim
no reason at all why not. if you have multiple lights on 1 switch, then it is sometimes the best way. methinks the college bods have been brought up on the 3 plate rose way, and think it's the only way.
Hi all
Thanks again
Jim
What was your lecturers take on it did he give a reason or quote a reg
Ask your lecturer the best way to wire a modern light fitting which only has 3 terminals.
Do you connect the neutral in the box behind the switch, or do you poke it up above the ceiling?
no, you poke the permanent lives up waiting there for the next unwary spark to fish around with a metal coat hanger.
Is good for numerous spotlights, not so good if customer wants a dimmer and the back box won't allow. Pros and cons to both
why not. make a few more qiud out of the tight fisted buggers if we have to fit a deeper box.
I thought the idea behind that was for the unsuspecting DIYer who thinks because the switch is off there won't be a live at the fitting so there's no need to go to the inconvenience of knocking off all the lights on that floor.
I agree with above posts, think he's just stuck in his ways. I've got a contract wiring up park homes and all the feeds go to the switch because the lights are either downlights or fancy light fittings.
Hi please can somebody help me
i got 4 lighting cables in back of the switch, on one it says bathroom switch, 2nd one it say hall switch and the other 2 hav no writing on them but 1 is live. The lights are both 1 way..it's 2 gang switch I usually do loop in at ceiling and take switch from there but I never done it this way please can u explain to me in detail
many thanks
many thanks
I would assume that the two unmarked cables are feeds, So the 2 browns/reds need to go into the top (common) of your two switches (Bathroom and hall) and loop accross between them, to continue the feed. Then take the brown/reds from the two marked cables and put one each to the bottom (L1) of each switch. join all the blue's (neutrals) together in a connector and the same with the earths.
That would be my guess, But i'd be tempted to message one of the more experianced lads on here. or get an Electrician who does know in.
Reply to Feed to switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
