the pict
Mentor
Dec 30, 2010
1,094
292
10,102,768
Brodick
Business Name
Devlin Maguire Electrical
Anyone familiar with fibre optics, while considering a trailer for my van I thought why do we use relays, bypass devices , etc is fibre optics viable bear in mind I know bugger all about the subject
Pict
Optic fibre is transferring only light. This light triggers a switch, so you still need power to the switch, same as power to a relay.
Ah right so you don't get usable light from the ends, cheers back to the original plan
P 9
I see what you mean now. Using the light from the vehicle lamps to be transferred through fibre, then somehow reflected in a housing to be used on the trailer.
You’d still need some sort of plug/ socket between vehicle and trailer.
Probably cost prohibitive but might be worth mulling it over down the shed with a little bit of help from Google and beer
Beer? Ah yes... the glass bottle makes a perfect refractor for the light beams
Reactions: the pict
If your trying to eliminate relays, you could consider solid state switches - they offer the same functionality but have no moving parts so are very reliable, especially in hostile environments.
Apart from the usual celtic/ rangers rivalry there is little or no hostility so no obvious detriment to electrical functionality, it's just the farkle around canbus wiring I am trying to avoid
Pict
the pict
Mentor
Brodick
Business Name
fibre optic alternative to trailer wiring
Auto Electrician Forum
the pict,
the pict,
