Discuss Towbar bypass relay issue in the Auto Electrician Forum area at ElectriciansForums.net
Armalig
Hi - I have just wired a 7 pin towbar using supplied harness kit with by pass relay . (2012 Megane Coupe)
1 issue discovered is my LED indicators on trailer remain permanently lit with dull glow? ( Checked trailer lights with another vehicle & lights are OK )
Otherwise lights works ok including flashing indicators/both sidelights & brakelight.
I have verified connections and supply feeds from lights as OK etc.
I have checked using meter & theres 12V at yellow & green wires (indicators) once bypass relay is connected causing this "glow". Yet this doesnt light up my circuit tester bulb tool that i normally use?? CAnt understand why??
One other smaller qry is pink wire from kit to do with reversing sensors which Im unsure of how to wire in... Dont think it contributary biut again advice would be aprreciate if possible
Trevor
Reply to Towbar bypass relay issue in the Auto Electrician Forum area at ElectriciansForums.net
Hello guys, just found the forum while searching for electrical help with my car not starting. I have a no start no crank issue. It's been...
44K
Thought this might be of interest and use to anyone looking to undertake the various short training courses. So here is my recent experience -...
4K
C
Hello and thanks for any advice offered. I've just joined so if I'm breaking any rules please forgive... My issue relates to my Renault Trafic...
6K
Hi Folks – there has been a lot of info re Immersion Heater Controllers on this forum and as I was updating and drawing up the circuit etc I used...
M
Hey all. Happy Easter. Advice needed again (no surprises eh?? :p - Don't worry one day I'll be a proper electrician!! :D) OK so I am sure...
mattcos1972
M
