Discuss Final Circuit Protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Locus
Hi Everybody
Why fuse is no longer use in Final Circuit Protection. Instead, Circuit breakers are used.
So far, I know that CB is more sensitive than fuse.
Can someone depicts any reason and their respective curves.
Have a look in appendix 3 of bs7671 for the time/ current curves of both fuses and mcbs.
Also fuses to bs 88 are still used for circuit protection for things like distribution circuits.
Perhaps you mean bs 3036 rewireable fuses no longer used?
Fuses can still be used if required, however a fuse requires replacement when it operates whereas a circuit breaker can (usually) be reset.
Therefore the maintenance costs are lower and re-energising a circuit is easier with circuit breakers so they are the preferred method.
Fuses may be used more often upstream in the circuit as they can provide discrimination and, if the cascading works, will not operate often.
Reply to Final Circuit Protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
I would like to get some information on what protection is on a multi meter when accidentally testing a live circuit while the meter is on the...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
