Discuss Fitting a built-in electric oven on the wall ABOVE the existing electric free-standing cooker in the Electrical Appliances Forum area at ElectriciansForums.net
I would like to have fitted on the wall above my existing cooker a single compact electric oven. The existing cooker (hob & oven) is electric & non-induction.
Under UK law would this be allowed? and, if so, what is the minium space allowed between the top of the existing cooker & the bottom of the oven that I am planning to have fitted?
Hope someone has an answer! Many thanks.
it's a bad design. suggest fitting oven in a different location.
Thanks for your reply - but when u say 'it's a bad design', do you mean it's a bad idea? I know it seems crazy but I do want to fit the oven in that position.
i suppose that if it'shigh enough above the hob so as not to be influenced by the heat from the hob.it's unconventional, but can't see it contravening any regulations.
Hi - need to consider manufacturer's instructions, so I'd email their Customer Services and see what they say. In the Building Regulations guides there are recommended minimum heights above hobs for extractor fan hoods. From memory it's 700mm. Then there's the existing cooker electric supply cable - it could be coming down in the wall there, just saying :) .
Reply to Fitting a built-in electric oven on the wall ABOVE the existing electric free-standing cooker in the Electrical Appliances Forum area at ElectriciansForums.net
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how my oven is currently wired up, followed by 3...
Hi, The current state of play is a standalone combined oven and hob supplied by single cooker circuit with 40A RCBO, 6mm cable, isolated by cooker...
