- Reaction score
- 739
Have an odd request. Customer wants a floodlight without sensor but a timer function so that when they turn the switch on it comes on and then turns off after a set time.
My first thought was a timer switch of some sorts. However, I was thinking if it was possible to install a standard floodlight with pir and disable the pir functionality? If so, would that be physically unwiring the pir or cover the sensor? Or can you set the sensitivity to the lowest setting and it wont activate?
