Discuss Grants in the Solar Thermal Advice Forum area at ElectriciansForums.net
Can anyone tell me if there are grants for air to air source heat pumps. I have an community hall to price for and customer wants to go for air conditioning. I want to go for ASHP with fan assist heaters. Any ideas
No government support, depends where you are though.
We have a number of local large corporates that have community energy saving funds, and have used those on a number of occassions to install air - air and PV on local community buildings, youth clubs, village halls, heritage properties etc.
ASHP with fan coils a lot more work to install and more costly, however there is the possibility of non-dom RHI for Air-Water only 2.54p / kWh of renewable heat, so needs metering as well, though it pays for 20 years, and if a private grant, it still qualifies. Lottery funding from any source is considered government grant so excludes you from FiT and RHI.
Reply to Grants in the Solar Thermal Advice Forum area at ElectriciansForums.net
I have a large gym in the garden and it gets ridiculously hot in the summer. I have utilised pretty much every inch of space and do not want to...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Evening all, Installed many extractors, but this is a first for me. Customer wants the fan vented out through the soffit, with an inline extractor...
My customer wants to be able to switch his heat pump (3.5kW) for his swimming pool on and off remotely, he also wants to be able to set times for...
Hello everyone, I am currently in the process of estimating the electrical demand for a new construction development that will consist of an...
