Discuss Green Brook Dimmable Ceiling Pull Switch - DIMPULLSW-C in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I have just purchased the above product but the installation instructions are a bit vague.
Please would you be able to tell me how to wire this fitting.
I have attached a picture of my existing product and also a picture of the new fitting.
I'm not sure where to place the live and neutral wires on the new fitting.
Any help appreciated.
John.
Red to L on the IN side and black to the opposite terminal on the LOAD side. The black is actually a live and should be sleeved red but not really an issue.
Hi,
John.
Well done for posting a picture of the existing setup. :)
So much better than a picture of a bunch of random cables ...
John, you will need red sleaving on the black to indicate that it is live and if you post the instructions up we may be able to confirm inline with the manufacturer's instructions the forum does not permit us to give step by step on how to wire.
Also looks like that new switch may require a neutral. Post a picture of the wiring instructions please.
The neutral terminal is only for the neutral wire if there are some there. It will operate with no neutral.
Reply to Green Brook Dimmable Ceiling Pull Switch - DIMPULLSW-C in the UK Electrical Forum area at ElectriciansForums.net
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi. Looking for some guidance please as I’m wanting to replace a ceiling rose fitting into a ceiling pendant. Done this many times but never come...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
