- Reaction score
- 0
Hi guys.
Got a client that wants to change their 'low voltage' MR16 35W lamps to mains GU10 5W LED.
The apartment is in a multi-storey block and above the plasterboard ceiling is a concrete ceiling so the floor to the upstairs flat.
They currently don't have fire rated fittings and don't want to go with the added expense of fire rated cans. I see the Part P regs doesn't required fire rated fittings in a house but not sure where I stand on the Part P in this particular situation.
Can I get away with just changing lamp holders to GU10 LED and not use fire rated fittings in this instance without breaking any regs?
Best to check.
Cheers
Best to check.
Cheers
