Discuss Halogen to Led in the UK Electrical Forum area at ElectriciansForums.net
Jamjar
Hi guys. I have a question out of curiosity if anyone can help.
I'm looking to change over halogen downlights to LED gu10 lamp holders.
Is it just a case of removing old transformers and connecting to new lamp holder and earthing?
Any advice would be great
Pretty much as you have described.
You should be checking the earth to make sure it is actually connected.
basically, yes. make sure the earth is continuous throughout. if the LED downlights don't require an earth, then park them on a terminal block. all connections should be enclosed, either with click connectors or similar, or wagoboxes. ( unless the new lights come with a suitable enclosure. I use these out of choice :
you can't change the bulbs. they are an integrated unit.
if the old downlights are in good condition then you can reuse them buy just switching out the lamp holders and doing away with the transformer.
you can buy gu10 holders
View: https://www.amazon.co.uk/Lamp-Holder-Regulation-Connector-Holders/dp/B0040XT1AS
then fit Fit your Led lamp
Many thanks for you replies guys. The lamp holder has the earth slot on the side so will connect it to that. Perhaps will need the sleeve for the earth
Reply to Halogen to Led in the UK Electrical Forum area at ElectriciansForums.net
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi. I’ve got two pendant lights that currently run halogen lamps. One of the converters is broken so I’m planning to change both for LED lamps...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
