Discuss Has this been done right? Im confused! in the DIY Electrical Advice area at ElectriciansForums.net
S
sjmleeds
Hi Guys,
I'm by no means an electrician but have never had any issues installing new ceiling lights, etc.
We've had an electrician re-wire the house and ive just come to fit the light fitting in one of the rooms, a ceiling rose. The light switch is like this, which has been wired as you can see, COM/L1, this done by the electrician.
The ceiling rose only has 1 wire coming through as so, with a L/N/E, no matter how i connect these to the ceiling rose it just doesnt work. Can anyone shed any light on it for me please?
This is a box room with no other switches/lights, etc. Just 1 switch and 1 light.
Thanks in advance.
SJM
Did it work before you dismantled it?
looking at that rose, there's no connection between the browns. connect browns together. must be a JB above. and looks like old wiring ( double red) has been used for the switch wire.
The brown cable should be in the same terminal; block as the brown flex, it's been wired from a JB
Not a full rewire then?
No mate they wires are the right colour so it must be OK
You know Murdoch I wondered what you were getting at, they old age and dementia creeps up on you well I see now what you were getting at twin reds eh, dohh
deleted .
Hi Guys,
Thanks in advance.
SJM
I hope you didn't pay for a complete rewire as you've been done.
What did the cert say?
Reply to Has this been done right? Im confused! in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
