Discuss Have the rules for ring mains changed over the years? in the Electrical Engineering Chat area at ElectriciansForums.net
I still like the flexibility of a RFC, as for fault finding them if you know what you are doing it is quite simple.
I have traced a faulty section down between two socket outlets in less than 2hrs, thats from coming through the front door and leaving, temp repair made dropped the mcd down to 20A because had to break the ring convert to radials temporary. Went back when could take the floor boards up in the area of the damaged section JB full of water.
It's not simple when you have a 3-story house with one ring and hidden JBs under floors with numerous spurs and cross connections etc. :(
Could be same with a radial and multiple branches. Still have to find the fault and disconnect.
But with an rfc, you might not lose the function of the majority of the circuit until repaired.
I must admit, when I trained ‘86 to ‘90 the journeymen I was with were really old school.
Sockets were always on a ring, unless it was only one on the circuit.
Radials were limited to individual points, such as. Cooker, shower, immersion, heaters, etc
It was very rare to find more than one point on a radial circuit
When at college 1980 ish 14 ed/ 15 ed not that the regs stated it I think, but the electrical craft principles book we studied from actually stated max numbers of sockets put on radials. Well it certainly weren't unlimited remember that much.
Have no idea how true but the old boys on-site were adamant you should only put 4 sockets max on a 20a radial
2.5mm, 20 amp protective device, 50 square metres.
Reply to Have the rules for ring mains changed over the years? in the Electrical Engineering Chat area at ElectriciansForums.net
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi guys I am looking to add 4 additional sockets for a room that is being converted for a bed ridden person. The room at present has no sockets in...
