Discuss Help for wiring an outdoor floodlight. in the UK Electrical Forum area at ElectriciansForums.net
Hi I need some advice/help as complete Novice. I have just purchased a new build and on this i have an outside light that is powered by a switch indoors. However I would like to install a flood light above it using the power that is supplying the existing light. There is a power block on the existing light where the power cables feed into, and the cables from the light connect to this block on the opposite connectors. Next to the block where the power cables connect to, there is an empty slot next to each of the Live, Neutral and Earth connectors. Could i simply connect some 1.5mm 3 core from these to the flood light block connector?
As this is to be mounted outdoor a brick wall would i need to use some conduit? If so how could i make sure the connections are water proof?
Thanks in advance for any help someone is able to offer.
as long as you want the floodlight to work off the same switch anf it's notone with a PIR sensor, just extend the brown/ble and gn/Y from existibg light. use 0.75mm black flex (pond flex is good) secured with 7mm black clips.
There is a power block on the existing the power cables feed into, and the cables from the light connect to this block on the opposite connectors. Next to the block where the power cables connect to, there is an empty slot next to each of the Live, Neutral and Earthconnectors.
I'm still trying to decipher this
Thanks for the replies it does have pir motion sensor on it
then you need a permanent L and N. maybe from the existing light switch? best get a local sparks to sort it for you.
Depending on how easy it is to take another cable out of the existing light fitting you might want to consider an appropriate IP rated junction box and then splitting to both lights.
Hi HK - you might want to consider getting some help with this job? I say this because it might not be an easy first job. While the electrical connections are likely to be straight forward, there are other things... You will be drilling holes and using tools while up the ladder, connecting conductors you're not familiar while balancing the new light on your knee, being neat and making it water proof. Just saying :) .
When I fit exterior light fittings, I try to fix them at the same height as the void between a ceiling and floor.
That way, I can drill through the wall into the void and most of the wiring can be hidden.
Hi here are the images of the light that is currently there along with wiring behind it. I hope i took enough.
The easiest option for you would be to replace this light with the pir one and use the switch as a isolator. You can connect multiple lights together. Anything else will require lots of extra work.
Yeah thats what i thought would be needed. How about if i wanted to raise the hight of the new pir light? How would i cover the exiting hole some one on the other forum that posted in suggest that i install a junction box
Get someone experienced to do it. Simple job for them......for you, plenty of ways to slip up.
Reply to Help for wiring an outdoor floodlight. in the UK Electrical Forum area at ElectriciansForums.net
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
