Discuss Help! New 2.5kW oven + 6.7kW hob - 40A fuse in the UK Electrical Forum area at ElectriciansForums.net
Hi. I need to replace an old oven and hob. Currently the oven is 2.3kW and the hob is 5.8kW. They are both hardwired into the same connection unit, then it goes to a 45A cooker switch with an integrated 13A switched socket, then it goes to the 40A fuse in the consumer unit.
The new oven is 2.5kW and the new hob is 6.7kW. Fragments of spec below.
BEKO HIC64402T Ceramic Hob
Hob power - Front right: 1.5 kW / Front left: 2.2/0.75 kW / Rear right: 1.7 kW / Rear left: 1.2 kW
Electrical installation - This product requires hardwiring to a 32 Amp fuse.
Power supply - 32 Amp (Requires hardwiring to a dedicated cooker circuit)
BEKO Pro BXIM35300X Electric Oven
Energy consumption - 0.94 kWh
Electrical installation - This product requires hardwiring to a 16 Amp fuse.
Power supply - 16 Amp (Requires hardwiring to a dedicated circuit)
Electrical power rating - 2.5kW
The question is - are these new appliances suitable replacements or should I look for something with less total kW? Will the total load be too much while cooking on the hobs and using oven at the same time? We very often also use the integrated socket in the cooker switch while cooking to charge a mobile phone etc.
Thanks,
Piotr
The cable is 6mm. About 6-8 meters from consumer unit with 40A fuse to 45A coocker switch with integrated 13A switched socket and then to connection unit behind the oven. Both oven and hob connected to the unit. All other sockets including fridge are on a separate ring/fuse.
Reply to Help! New 2.5kW oven + 6.7kW hob - 40A fuse in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
Hi all, I replaced my old Electrolux oven which operated with a 13 amp plug. The new Kenwood oven I ordered says a 16 amp (Requires hardwiring to...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
