Discuss Hi in the The Welcome Forum area at ElectriciansForums.net
R
referee1472631
Hi wonder if anyone can HELP me,I have a sunvic TLXRFP thermostat which was in the house when I moved in but now it will not turn on the heating.I can get hot water and I cannot get heating the stat is asking for the heating to come on but the reciever is not switching on boiler.I have changed batteries in remote and fuses in switches.Any HELP would be appreciated.THANX
:confused:
Hi,
To be honest, im not sure this kind of problem can be sorted on a forum and you may need to contact a local electrician.
However, there are a few members here who have good knowledge of CH systems and may be along soon to offer some help.
Reply to Hi in the The Welcome Forum area at ElectriciansForums.net
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
So I’ve been having this issue with my boiler for a while now, I’ve currently got one stat in the hall that when I turn it on it brings the...
