Discuss house alarm trouble in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
B
bobby101
hi all just wanted to know if anyone knows a quick method of silencing a bell box even when the main panel is disconnected and the main battery is disconnected just thought i would ask cause my neighbours are not happy ps im not able to reach the bellbox(no ladders) DOH!!!
disconnect during the day. it will sound for a while, then run down, flat.
well that comes under not reasonably practical so just climb up the bricks like spider man,tho being serious it should time out after 20 mins,probably wont tho,dont try the 240 up the bell cable,can work,can also cause a fire,you could call a alarm engineer or a spark to diss it,or leave it and take the wrath of your neighbours and the council
Reply to house alarm trouble in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hi Guys/Girls A quick question. Would I need to TT a stand alone socket detached from main building (TNCS) that could be used with a Class I...
