Discuss How to measure rail-to-earth resistance and rail-to-earth potentials in the Industrial Electricians' Talk area at ElectriciansForums.net
Dear forum members,
Would you give please a practical tips how to measure and what measurement equipment to use (with some examples if possible) to measure the rail-to-earth (tunnel) resistance and rail-to-earth (tunnel) potentials?
The measurements needed to be done in the tunnel (cast iron tubes) and above ground also (soil and ballast under the tracks) ?
This is a DC traction metro
Thank you so much.
Dear forum members,
Thank you so much.
Welcome to the forum!
To be honest I think this is a subject for proper training and procedures rather than asking on a forum.
Is this something you need to do as part of your job on the railway?
Reply to How to measure rail-to-earth resistance and rail-to-earth potentials in the Industrial Electricians' Talk area at ElectriciansForums.net
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
What are the dangers of poor insulation resistance results (i.e <1Mohm) between neutral and earth? If all other tests are ok, what are the...
5K
A 'Sunday challenge' for the qualified electricians.... Can anyone explain why a built-in gas meter housing box that is located 600mm above a...
6K
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
