Discuss Imersion heater advice in the UK Electrical Forum area at ElectriciansForums.net
Hi all im just after some advice ive currently moved into a flat and only has electric and an imersion water tank there is a switch to turn on and off but was woundering if there is any way of changing this switch to a timer so it heats up at night when my electric cheap and is turned of during the day i would be getting a professional to do the job bit just wanted to know if its possible and what type of switch to biy thanks
Reply to Imersion heater advice in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
