- Reaction score
- 965
Was sent a EICR report the other day to quote the remedial work. Just thought I would share the highlights with you .
This is a school and all observations were code 1 or 2s
Lighting Circuits require further investigate for ethnic continuity
RCBO for shed must be hanged for amcb - RCD Confict
For all lighting circuits in all fuse boards DB1-DB5 if not RCD o RCBO protected.
All sockets circuits protected by MCB 32A in all fuse boards DB1 – DB5 if not RCD or RCBO
protected.
In this report “bath or shower” means special location such a toilet or other rooms where metal pipe
can be reach form power point.
For all hand dryers and water heaters located in the school.
All circuits supplied equipment in the toilets, boiler room connections, water heater if not protected
by RCD or RCBO.
The Report was done by a NAPIT Registered Company
I have advised the customer a site visit will be required to try and find out if anything was actually inspected properly
protected.
by RCD or RCBO.
