Discuss Intermediate switching in the UK Electrical Forum area at ElectriciansForums.net
Good evening all,
Just a quickie, if I wired a switched live and neutral to an intermediate switch could it still work?
2 way switch - feed and 3 core
intermediate switch - 3 core 3 core and switch live and neutral
2 way switch - 3 core
I’ve not made a mistake, I’m just a bit curious!
cheers big ears
rare to see a neutral at an intermediate switch. more info required.
An intermediate switch would swap the live & neutral over if wired as I think you describe, so no normal switching action as such.
A diagram might help!
More info need, pic would help or diagram, but I am assuming you have LN at switch plus pair from light to switch?, if so 3core&e to all other positions.
You can take a feed to the first 2-way, with line on COM and neutral to a connector. Then send the two strappers from L1 and L2, and the neutral, down the 3C+E. At the intermediate, strappers go through the switch as usual and N simply passes through another connector. At the second 2-way, strappers finish at L1 & L2 and the light is fed from N and COM.
It's the same as a 'conventional' 2-way but with the neutral tagging along too. At no point should the neutral connect to any of the switch terminals!
FWIW an intermediate is a cross-connected DPDT, that will function as a polarity reverser, not that it is designed to have L & N across two of its terminals.
Guys, I haven’t wired up anything,
It was just a question I was thinking about on my way home.
So it would work if you had the permanent feed at one of the circuit end and the S/L at the other end of the circuit but not if the S/L is in with the intermediate?
I’m certain it won’t work, again, just curious!
Your strappers are a continuous metallic path , does not matter how many positions you are switching, so why talk about N at intermediate position.
Yes, you can feed the light from intermediate. The two strappers run from end to end as before, going through the intermediate switch, using two cores of the 3C+E. The third core in the 3C+E from the supply end 2-way to the intermediate carries the neutral to the intermediate position. The third core in the 3C+E from the far end 2-way carries the SL back from the COM to the intermediate position. N & SL can then be jointed to the cable to the light.
[automerge]1594328405[/automerge]
Look at my pic in the previous post!
Just saw this!
you’ve answered my question ,
Reply to Intermediate switching in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hopefully just a quick one, but I can't seem to find a definite answer. Will a push to break/make (ie not momentary) 2 way retractive...
Hi Eveyone. I'm curious about the 3 way switching arrangement similar to that seen in a hotel room. Switch at door with two additional switches...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
