A
arturas
Hi there,another question from me,I have a 10mm radial for oven&hob,so doing IR test It shows me 0.22 between neutral and earth,so I went to investigation what could cause a problem,there is a 60amp JB for that circuit above the hanging cupboards in the kitchen,so first thing I did,disconnected the junction box,now testing from CU to JB point it shows >999 , testing after JB to isolator and 2 connection points it shows >999. As soon as you connect them together it shows 0.22, then I left JB connected and disconnected the isolator, now from CU to isolator >999 after isolator to connection points >999. Now I have checked incoming neutral from CU and outgoing earth which goes to connection points and that's where it shows me 0.22. I did 250v doing with higher voltage tester sends maximum 288v.LE and LN are >999 all the way. So I was thinking what could cause it,any ideas?R1+R2 is 0.12.all test was done with circuit disconnected from CU.maybe anyone came across with something similar?
