Discuss Is it possible to wire two power sources to one three position switch in the Auto Electrician Forum area at ElectriciansForums.net
Garuuu
I would like to know if it's possible to wire two power sources to one three position switch with six pins, this is for my foot's well lights in my car the problem I have is the original lights I have wired them to switch off when the car is running and I would like them to stay on so I was thinking if when I switch the power source over when the original source switches off I could switch it over using the switch to the other power source. is this possible?
you would need to make sure that both feeds to the switch were on the same circuit. basically you'd have the lights in common and one feed to each end of the 3 position switch
not sure how it's wired to go on when car is off - relay?
must be a relay that is N/C. when the ignition is turned on the relay energises and switches to N/O so the lights go off.
could be a problem,,, can't see how, if the footwell lights come on with interior lights, switching the footwell lights on without it feeding the interior lights also. maybe someone with more auto electrics knowledge can help. i ain't got my head round electric windows yet.
That's why I will be putting a 3 position switch pos 1 power from original footwell lights pos 2 power from something like the cigarette lighter and pos 3 is off
why would you need the footwell lights on whilst driving. is itin case you drop your phone/booze/smoke/spliff?
Reply to Is it possible to wire two power sources to one three position switch in the Auto Electrician Forum area at ElectriciansForums.net
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi everyone, On my Hiace the roof LEDs are triggered by the side door that breaks the ground, not the positive wire. I want to also have an...
Hi all, the main horn on my Fiat Punto stopped working - went around the houses to fix it including the clockspring but to no avail. Now wired up...
