Discuss Is there any asbestos in meter boxes? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
I was contemplating cutting a hole in the bottom of a meter box and I decided to have a quick check on line. I have now used an existing hole albeit a harder route. How common are meter boxes with asbestos in them? Is there any way of knowing if it contains white asbestos?
Drilled far to many to worry about it HHD
Is there any way of knowing if it contains white asbestos or a bomb ?
lol. four sheep .
This was one of the online sites that caught my eye
But.... looks like that's an Australian address so we're all safe here!:)
without seeing the box's we cannot say for sure,
but YES ! many of the older box's had asbestos in them.
It's usually safe to work on them, but if your drilling holes ?
then use a vacuum to suck up the dust.
Whilst it just requires a little comon sense
your not gunna fall down dead at the first touch of asbestos.
No! Never use a normal vacuum cleaner to suck up dust that might contain ACMs! It will not filter all of it out of the airstream so will spread it around the room, and may continue to do even after you've changed the bag and moved on to another job. Work wet, damp the dust, contain it at source etc.
DMX is also in Aus. Do we have a verdict about UK meter boxes? In the UK we didn't really have meter boxes until after the asbestos era. As above. the traditional white ones have always been GRP.
HHD did you have a pic of the suspect box or one like it?
As far as I know outside meter boxes in the UK have always been made of a GRP material with a chipboard meter board.
Mantel boxes were always metal with a chipboard meter board.
Some blocks of flats, council estates etc have a meter cupboard lined with asbestos board which obviously needs a careful approach.
It would need to be an H Type vac and you would need to be trained to level/Cat B working with asbestos.
No it can take up to 50 years, but it will kill you eventually.
QUOTE - No it [ can ] take up to 50 years, but it will kill you eventually
can being the operitive word !
Some old boards did have asbestose in them,
if you have to work on one,
then using common sense precautions is usually sufficent.
such as a dust mask and a vacuum cleaner.
The chances of coming across an asbestos board is low,
They were only used 50+ years ago,
So not many electricians see them,
Yes I am in Australia,
and have seen and worked on many boards of advanced years
perhaps that is why I have seen them
when many haven't.
Just checked my photos Lucien, no pictures I'm afraid. It's just a standard 'looking' meter box from memory. I think it was the general look of the texture of the box that got me thinking, however I feel 90% confident from internet research that UK meter boxes will not contain asbestos.
As for the 50 year thing, it can take less or more. I don't intend to take any unnecessary risks having seen the ugliness of mesothelioma and asbestosis up close.
Using the correct dust mask and the correct vacuum yes, they need to have the correct level of filtration otherwise the asbestos dust will go straight through the filter.
Reply to Is there any asbestos in meter boxes? in the UK Electrical Forum area at ElectriciansForums.net
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
On another forum for general EV chat this question comes up all the time. It's very common to install a charger taking the supply direct from the...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
