Discuss is this dangerous in the The Welcome Forum area at ElectriciansForums.net
M
misslaura
hi there , im wondering if anyone can help me, ive just moved into a flat and this box thing on the wall looks dangerous with these wires not coverd up. is this dangerous? i didnt notice it when i was shown around the flat. thank you.
[/IMG]
not dangerous at all. those cables are insulated and sheathed. only possible deviation is the IP rating. the top cable entries should be sealed so that a probe >1mm should not penetrate into the enclosure ( IP4X). a splodge of sealer can fix.
looks a bodge but not dangerous so long as the insulation is intact, plus their double insulated cables so double safe and at that height you're unlikely to be touching 'em.
if you want to pm your address i can bob round and "investigate"
bit of a jaunt , leeds to coventry.
Running the cables on the surface is actually a safer way to do it because you can see where they are and would be far less likely to drill through them than if they were buried in the wall. Granted it doesn't look pretty, but safety should always come first.
Slightly off at a tangent, there appears to be a switch in the bottom left of the picture, which is currently partially obscured by that shiny panel. Is the panel easily moveable to be able to access the switch?
I had to giggle at that - no offence Adam. Rob
Ps - awful place to either put a door (shiny or not) or trunking. There are some messes out there. Good that we all have cameras on phones!
If it's not that type , it's Magnolia and twist carpets , or curled up saturated laminate.
yes it's a door... lol. and I don't think them boxes feed the house next door as switched them off a few times. there the on peak and off peak . and my decor is nown as... red. ghastly colour to have in a hallway. what was I thinking.... sarcasticly said
Reply to is this dangerous in the The Welcome Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
HI I am not a professional electrician but have cabled all my houses since starting to build them 30 years ago. I know a dangerously small...
Im starting a re-wire of a top floor flat, they have run an 16mm T&E with a 6mm earth from the ground floor to the 3rd floor feeding the CU...
