Discuss Is Wickes twin and earth any good or should I get Prysmian? in the Electrical Tools and Products area at ElectriciansForums.net
Have a read of the cable sheath, sometimes some of the bundles of cut cable they have available will tell you the make or brand...
It also depends on what you are using it for, and how much you need? if its just a meter or 2 then go for the best value, if a whole new circuit then the best your budget allows.
The quality,and therefore the cost,should be proportional to the length of time you expect the item to remain functional and trouble free.
A cheap lamp can be easily swapped for a better one...installed cables are a little more troublesome...
Reply to Is Wickes twin and earth any good or should I get Prysmian? in the Electrical Tools and Products area at ElectriciansForums.net
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
hi....im running cable for a split type 1.5 hp aircon....i have a roll of english 2.5 twin & earth, is this ok for the job? im running it to the...
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Good afternoon, I purchased a 25mtr coil of PRYSMIAN 6242Y 2022 GREY 2.5MM² TWIN & EARTH CABLE in Screwfix at the start of July and found while...
