Discuss Kitchen electrical dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, I was just wondering if I have a dishwasher on a circuit of its own so I'm looking to put a double socket beside the fused spur in kitchen used for the dishwasher is it ok to just spur of the dishwasher fused spur straight into the double socket.
Possibly not, but, Possibly.
It depends on a number of factors (this list isn't exhaustive);
  • Whether or not you plan to take from the feed or load of the spur.
  • Size of the OCPD and whether the CCC of the cable could take a larger OCPD if necessary.
  • Size and type of the cable.
  • Current layout of the circuit length, composition and routing.
  • Whether or not there is RCD protection.
  • The Current state of the circuit and whether its fit for continued use of alteration.
If your unsure of any of these then its probably better to get an electrician to do it for you, it may cost less than you think and in the end can you put a price on the piece of mind that its all done correctly?
Reply to Kitchen electrical dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
Wiring to new dishwasher causes garbage disposal to stop working. I just installed a GE dishwasher and came across a problem with the...
Sorry two questions today. We had the kitchen rewired based on existing units, but with a slightly new layout it puts the dishwasher right over...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hi I am looking at where does my dishwasher leaking. I find there is some leaking at the bottom behind but not from the hose pipe inside , since i...
I wonder if any one can give me some advice. I live in a fairly new build house it's 11 years old. In our kitchen there is a fused spur switch on...
5K
