Search the forum,
Discuss Lat and plaster in the UK Electrical Forum area at ElectriciansForums.net
Try spring toggle bolts to hold the box onto the lath. you can push them between the lath turn them by 90 degrees or stick a piece of 3ply to the cleaned up lath if the plaster is thick enough and screw onto that. unless youfind the supporting frame location first and fix it to that. Re-aplying the plaster reduces the flex of the lath. each method has worked for me.
If trying to fix a box to the surface of a lath and plaster wall always drill a small pilot hole in the lath then screw in a screw this then means that the lath doesn't split but the screw grips tight
This has worked for me in the past - there are a lot of old houses in my patch.
Mark and cut out for a metal back box using a sharp pad type saw using the back stroke to cut and try using a piece of board pressed against the wall adjacent to your cut to help support the plaster and stop it breaking away. Then, cut a batten twice as long as your hole and fix it to the wall the other side of the cavity with multiple screws from the other side, I know this means a few small holes to fill but you will then have a really secure fixing for your back box. I used this technique recently in a 200 year old house to mount a shower isolator with 10mm t+e cable onto a wall made of reeds and plaster. Worked great.
Reply to Lat and plaster in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Hi all I have an outdoor wall light which is bolted from behind. Then a decorative nut threaded on the front. As I push the plate on the bolt...
Plasterer has been in this week and after leaving today, he left the light on in the room. I went to the room to turn the light off and saw the...
4K
Hi everyone My mira power electric shower is not doing anything when i press the power button. There is no led lights to check on the unit to...
