Discuss Lead cabling in the The Welcome Forum area at ElectriciansForums.net
P
pippasmum
I am having a terraced house (circa 1900 build) renovated. Builder has told me that he has found lead cabling after removing door frame. Is lead cabling legal and safe? I will need an electrical certificate as I am going to rent the house out. My main priority is safety.
you will generally find that the insulation has perished where it is exposed to the air. however, a good idea would be to have a EICR done. this will tell if the cabling requires replacing.
Its quite possible old and dis-used but as others have said i would have an EICR to conform this and from a landlord point of view i believe Reg' are changing and been tightened up and if i remember rightly that shortly if not already you will be required to have RCD protection on the electrics, up to press if the installation was say under 16th edition it could be deemed as compliant.
Thanks guys, I have an electrician coming tomorrow so presumably he would do this EICR and advise on the regs for landlords (I only have this one house so am not well up on all landlord requirements).
Reply to Lead cabling in the The Welcome Forum area at ElectriciansForums.net
There are electrical engineers who just mutter the slogan "Safety is the top priority," and simply convey old and inaccurate Cable Tray Weight...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hello. I'll apologize to start with as due to my lack of knowledge on the matter I'm likely to waffle a bit and call everything by the wrong name...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi guys, Whilst renewing my loft insulation I came across a few runs of very old cable. (Please see attached pictures). These cables are lead...
