Discuss LED fluorescent replacement tubes in the UK Electrical Forum area at ElectriciansForums.net
UNG
Mentor
I have a customer who is trying to reduce his electricity bills at his shop, lighting is the biggest load with multi tube fluorescent fittings in the main shop area
I have been looking at the possibility of replacing the fluorescent tubes with LED tube replacements but have some doubts not least having found this ESC report which obviously highlights some safety implications having modified the fitting to accept them and also the quality, cost and longevity as to whether the long term savings will be made
Has anybody used or got any experience of these LED tubes and did you achieve the expected results and were there any problems or issues with them, been talking to a wholesaler who is very enthusiastic about them and tells me he is doing good business with them with no failures but not sure whether this is just sales spiel
You can get direct replacements for T8 fittings 4-6ft I know that. Wouldn't ask your wholesaler though, asked mine about them and he quoted £40 a tube for ones which put out less light than some £14 a tube ones I found online better off sourcing them yourself in my experience but everywheres different I suppose. But to be honest it's just an emerging technology at the minute, I wouldn't say it's worth getting them right now you may as well get T5s to replace. Simply because the light is no where near as good so you might get a lot less light depending on how many fittings are already there, replacement LEDs might not provide adequate light
I've concluded after my asking and searchingto just order 1 or 2 and try them. And read specs what you buying as they do vary
Reply to LED fluorescent replacement tubes in the UK Electrical Forum area at ElectriciansForums.net
One of the fluorescent tubes in my undermount lighting system burnt out. There are 3 independent tubes/ballasts under the length of the kitchen...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hello! Hope you’re all keeping well! I’m replacing a fluorescent tube light which had an electronic ballast fitting - I’ve ripped this out and...
Apologies for starting a new thread with this question. I tagged it on to the end of my other thread, but I fear it may get missed, hence...
