Discuss LED Tape recommendations in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Hi All
Unbelievably I have never fitted LED tape and have always chosen LED battens.
I have an under cabinet approx 1.5m long, any recommendations for a make type or supplier gladly recieved along with any top tips for fitting.
Not sure about make/type but don't rely on the adhesive for fitting. Use extra fittings to fix it up.... So I've been told...
I've been using PowerLed tape and drivers recently, supplied by Yesss Electrical. Seems quite reliable so far. The drivers are quite bulky if you are trying to hide them under a unit though.
Hi All
Ledridge for me there stuff is excellent.you put a metal trim up then stick the tape to the trim so no cleaning units etc to get it to stick.have it i my own kitchen for over a year and done loads of kitchens with it and never a failure yet.advice do not use tamlite made that mistake many years ago hence why I do not use cef
In the end I picked up some tape and aluminium extrusions from my supplier. Stuck the aluminium on with industrial double sided tape, impressed with results so not going back to strip lighting! Thanks for advice!
Reply to LED Tape recommendations in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Ive got an old T5 (or4?) fitting to change to LED, but its built into the kitchen cabinet between two shelves of glass. Is there any like this...
