Discuss Light switch two gang, standard and loop through in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jase31
Is the any reason why you shouldnt fit a two gang switch, one wired as standard (switched live with 2T&E), and the second switch looped with the L-N passing through the switch (neutral in a wago). This second circuit is to power 5a sockets.
Would it be preferable to take a permanent live into a JB, and then run the switch cable up to the switch in the usual manner
Can't think why not. Just make sure the relevant colour sleeving is on the cores to identify them as live neutral etc.
You could always replace your switch drop (if possible) with 3C&E and use the extra core as a neutral (Brown = switch feed, Black (sleeved brown) = switch return, Grey (sleeved blue) = neutral) with commons linked in switches. Then off in T&E to your 5 amp socket(s).
This would mean only having 2 cables at the switch instead of 3.
Or just loop in at the switches and run SW/N cables out to lighting points.
I normally find that's the best thing to do when you have the likes of four and six gang switches in kitchen for the likes of ceiling downlights, plinth lights, pelmet lights, island lights and all other manner of lights!
Reply to Light switch two gang, standard and loop through in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
i know about the different wiring arrangements for 2 way light switching. i want to connect the permanent live into first switch common, connect...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
