Discuss Lighting Circuit Diagram Check in the Lighting Forum area at ElectriciansForums.net
Hi, I want to know if this wiring diagram makes sense. The circles are lights and the switches are indicated. I want the 4 lights on the left to be controlled by switch 1 and the 6 lights on the right to be controlled by switch 2. The power is indicated and will go to a light first. I am reusing an old circuit with nothing else on it and it is easiest to start where indicated.
https://www.------------/photo.php?fbid=10161232226025641&set=a.10156171923105641&type=3&theater
Reply to Lighting Circuit Diagram Check in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi everyone. I live in an older home that still has a few circuits with aluminum wiring. One of these is a lights-only circuit that contains 6...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
