Discuss Lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
Don't know if this helps the OP at all. Note the highlighted switch wire joins the middle live terminal to the light. It should be marked with brown sleeving/tape (or red if old colours). Many out there aren't marked and you have to learn to work out which one it is.
exactly, i think your right bud, should I have put this in with the lives? Its wasn't a rosie it was led light.
Makes no difference, rose or light fitting. A switched live cannot connect to a neutral.
See the diagram someone posted above for how lighting circuits are wired. This will answer your question of where the switched live goes.
Reply to Lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
