Discuss little advice please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1983
Hi all after some advise please. A shop with a basment and flats on top has a tns 2phase and neutral supply one for shop one for flat. doing ze test am I right thinking that if I disconnect the main earth wouldn't that put the occupier of the flat in danger?
can you diss. the main earth just from the shop CU, leaving it connected to the flat? alternatively, you could isolate the flat CU.
Yes it most certainly would, you need to arrange a suitable time to do it convenient with both. You only need to disconnect it from that installation and ensure bonding to gas and water etc are disconnected to avoid parallel paths.
If you disconnect the earthing conductor with the installation live then yes you are putting your life at risk along with the lives of any users of the installation.
Thank you for your feed backs appreciated. It's for my niceic assessment if he was to ask for me to do a ze test. Davessparks I was going to safely isolate my side but realised about the flat on top seen as they share the same earth back to the tranny
Before disconnecting the earthing conductor you must isolate the installation at the main switch so that the whole installation is dead. Failure to do so places your life in danger, the leakage current flowing through it may be tiny, but don't forget it could take as little as 0.05A to kill you.
You cannot measure Ze without having disconnected all cpcs and bonding in the installation from the suppliers earthing connection.
This basic concept must have been covered at some point during your apprenticeship surely?
If he can't figure a simple thing like this out it makes me question
A His ability
B Is he ready to proudly wear the NIC badge of competence
C Why the hell they'd let him (Although I know the answer to that one = £ )
A His ability
Is that little worky ticket messin aboot wi' yer siggy son??
Get yersel away doon an introduce 'im t' the Geordie kiss!!
Reply to little advice please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I am currently in the process of quoting a job to renew the mains for 19 flats. This is the first job of this type that I have quoted so...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
