Z
Ziggy1979
Hi Everyone
apologies for not posting in the DIY section but it's locked and not allowing new posts.
We've seen IP65 rated small decking LED lights at Wickes which we thought to use in the bathroom, set into the wall (skirting level). We hope to fit them under a wall hung sink and toilet and possibly around the bath (bath side and end panel are tiled). First things first, is this safe? They are exterior rated, pressure jet rated and IP65.
If safe, the lights come ready to fit onto a 3 pin plug, which plugs into the ring main. We want them on the upstairs lighting circuit (circuit has RCD protection (split load consumer unit)) operated by a normal light switch in the wall. Is this safe/allowed?
Thanks a lot for your help!
