Discuss Main Earth Problem in the Electricians' Talk | All Countries area at ElectriciansForums.net
T
TPES
Evening all.
Just a quick one, not done much 3 phase, Ive added photos of a job i went to today, all the bloke wanted was additional sockets putting in his workshop.
The existing install is a right mess, he's telling me some sockets in his shop work, and some dont, and the same with lighting. I recomended to him it really wants sorting out as its unsure whats live and whats not.
At the end of the job i noticed that someone has cut the main earth, near enough flush with the supply. (you'll see by the photos)
There is only about 1.5 inch gap at the side to be able to get in there. very tight.
Is this a job only the electricity board can come out and repair?
or is it a job easily done by myself? i cant see how to get into the terminations to reconect the earth??
I have told the customer how important this is to get repaired asap.
Cant be the main earth surely.......can it??
Why in gods name would someone chop it, I'm absolutely speechless.:eek:
Exactly!! seems to be a vandal, or a very unhappy sparky in the past, it makes no sense at all to me.
I think you better make it your FIRST call in the morning and get that sorted.
To be honest bud, you probably shouldnt have left it without sorting it one way or the other.
Good luck!
Yeah i am going back in the morning, I just wanted to know how easy this is to repair, As i have now been told by 2 different sparkys this is down to the suppliers to sort out.
As its in such a tight space i'm struggling to see how this comes apart for me to terminate. any help apreciated.
Im assuming its PME, so on the far right of the cutouts, there should be a plate held in with a screw and its probably sealed.
That is where your earth connection will be, however , i strongly recommend you contact the DNO on their emergency number and explain the situation to them.
I think you will find they will there before you hang up the phone.
If THEY supply and earth point, it is THEIR responsibility to maintain it.
I'll be totally honest, if it were me I'd have been busting into that cut-out myself as soon as I saw it to connect in a new earth, then pick up the phone.
I'll get my hammer on it first thing in the morning, I'll find a way into it. I was just very unsure about touching the supply authority's property, as jason said. Its there responsibility. I'll make sure its done asap. as its the customer who is at "High risk"
Reply to Main Earth Problem in the Electricians' Talk | All Countries area at ElectriciansForums.net
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Is anyone aware of any galv trunking that is smaller than 50x50. I'm drawing a blank online. I've taken over a job that's used 16mm twin and earth...
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
