Discuss Mains supply Blocking diodes ??? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
K
keith1st
Hi I'm new on here so apologise upfront if I've posted in the wrong place. I was going to ask for advice in the solar forum but I think I may need help from both sides so will try here first.
OK what I would like help with please is. I have a grid tie solar system which is feeding back to my meter when producing more than my consumption and the meter is reading this as if it where coming in from the mains and I am being charged for it (we have no feed in tariffs where I live). I can not have the meter changed so I would like to know if there is a way I can stop this reverse flow with a blocking diode or similar after the meter ? And can it be done in a way that will not affect the inverters grid disconnect protection ? Hope this makes sense to someone out there.
I don't think this is possible as it's AC.
I met a guy in France a few years ago who had similar problems. He is a bit of a mad proffessor type and was charging UPS batteries that he'd bought on eBay which he used to run some circuits in his house through an inverter. I really couldn't see what he was gaining for all the effort other than the personal satisfaction of his invention!
Anyway, I hope someone else can think of something to help you...
i would take this question up with the manufacturer of your solar units
without being there to see the hookup and the schematics i cant really give much info on it
Reply to Mains supply Blocking diodes ??? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Can I add solar panels to an existing system without jeopardising my feed in tariff? I have a 3.8kw system but was thinking of adding a few more...
