Discuss MCCB as a switch disconector in the Commercial Electrical Advice area at ElectriciansForums.net
The majority are single phase, there is an intention to install a 3 phase oven at a later date fed by a 16 amp switched commando from the same board.
Yes, it'll generally be an option on most premium manufactures DB's. Virtually all our 3 phase plant room DB's have MCCB's as the main isolation switch. Most of them featuring ground fault, along with other adjustable protection facilities....
Thanks lads appreciate your help.
Reply to MCCB as a switch disconector in the Commercial Electrical Advice area at ElectriciansForums.net
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Looking to use this brooks Compton motor as a replacement in an electric cement mixer. can anyone tell me if it is designed to operate off a...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
