SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Discuss MDF as meter board in the Electrical Forum area at ElectriciansForums.net
davidl
Good evening everyone,
I have always used 18mm ply for new meter/cu boards, but i,ve got some 18 mm MDF left over from another project, can anyone think of a reason not to use this?
Kind regards
David Long
P
Plonker 3
  • #2
What is wrong with the the surface you fix the MDF too, to directly fix your equipment too it?
davidl
  • #3
Evening Dillb,
Thanks for the quick reply, nothing wrong with the wall at all, I just like to stand the board off the wall with battens behind to hide the cables witha back entry into the cu. David
P
Plonker 3
  • #4
Each to there own, but unless the wall is in terrible condition then mounting directly too it is the best was to mount DBs in a domestic environment.
I don't know Dillb, there's a lot to be said for rear entry (fnarr fnarr). It usually means you don't have to worry too much about the CU's IP rating
Instyle LED Lighting Specialists UK
Reply to MDF as meter board in the Electrical Forum area at ElectriciansForums.net
Top Bottom
